3D printing
jivekore
I'm a long time CA user and was wondering if anyone has tried to 3D print a model?  The stl export from CA x6 is pretty ugly for that purpose.  I'm sure I can find a way, but I'm hoping to save myself alot of time.
Thanks
Dave
Sounds about the same as my experience.  I used MeshMixer to fix the shells, but then it erases all the doors and windows!!  Makerware will only work with Makerbot (you may be able to use it in a pinch if the build area of your printer matches a makerbot model).  I am using a Hyrel 3D System 30, which is a more expensive "prosumer" unit ($4500+/-) - this is at my day job though.  I have a less expensive 3d printer on order for the house ($350).
For anyone who's interested there are several 3d printers in the sub $1000 range (& even a few around $500) that will provide decent prints.  They will require a higher learning curve than the more expensive models.
