Material List Generated.....
buzzsaw204
hi,
just wondering if some can shed some light on this....
i've drawn 2 piers... (16"dia. x 25' deep)
one by generated for drawing the foundation wall, the other by using the draw Slab function. both have the same dimension. so, both should be 35 cu ft = 1.29 cu yd.
but when generating the Material List...
the auto generated Pier in the foundation wall is 20.69 Cu. yd, which dont make any sense.
and the other "Slab-concrete" pier is 1.29 cu. yd....which is correct.
any idea why the discrepancy??
Pier Test.planFetching info...
