No Deck Cantilever & Deck Joist direction
country
Is there any way to set the defaults so the deck support beam and posts are not stepped back for a cantilever?  I never have a cantilever and usually have a roof over the deck so require supports directly under the roof supports.  This situation comes up on almost every plan I draw.
I also would like to know if there is a way to frame the deck in at 90 degrees when it is wrapped around a corner.  The program always puts the joist direction the same even when I split the spaces up but maybe I am just not doing something in the correct order.
