Converting a roof plane into a polyline?
M3taMorpHous3
Hi guys,
Is there a simple way to convert a roof plane back into a polyline? (ie. to remove it's "roof" properties & just use it as a shape?) This would come in handy on a site plan for instance, when I want to show the overall outline of the roof with some "fill" properties.
Cheers, Nathan
Nope, I do not think so. But you can do this....... select one roof plane at a time, copy it, open new plan, PASTE IN PLACE, turn new plan into CAD LINES, select the lines from the roof shape, make sure it is closed, give fill, copy and now go back to original plan and PASTE IN PLACE.
Display only roof planes.
CAD/CAD Detail From View.
Copy/Paste-hold.
Absolutely,  I was not sure if they would be closed plines,  hence doing one roof at a time,  but Jim is correct, do all roofs at one time.
