Turn off wall joint/corner warnings?
clfrycreative
Go to solution Solved by DavidJPotter,
Anyone know how to get rid of the the broken wall joint/corner warning (shaded circles on the corners and icon that follows the cursor around) without having to redo the corners every time? The corners display fine, and the warnings come and go (this happens multiple times somewhere on almost every plan). It usually happens when I have to do a workaround for a non-standard or complex wall scenario. Is this something that can be turned off?
