adashmore Posted August 17, 2016 Share Posted August 17, 2016 Just modified an exterior wall to show the wall below the roof line as an interior 6. When doing so, the door in that wall is shown in the plan view as a door but the wall is continuous through the opening. Is there a way to display as a typical door location without the wall going through the opening? In elevation the door is shown correctly. Link to comment Share on other sites More sharing options...
HumbleChief Posted August 17, 2016 Share Posted August 17, 2016 Are you on the correct floor? Sounds like you might be on the attic floor looking for a doorway on the floor below? Wild guess. Link to comment Share on other sites More sharing options...
adashmore Posted August 17, 2016 Author Share Posted August 17, 2016 Are you on the correct floor? Sounds like you might be on the attic floor looking for a doorway on the floor below? Wild guess. I am on the correct floor, the view changed when I changed the wall below the roof line to an inside wall in options. I went back and changed the wall back to its original and the doorway appeared again without the wall running through it. Thank you. Link to comment Share on other sites More sharing options...
yusuf-333 Posted August 18, 2016 Share Posted August 18, 2016 Are you using pony walls? if so, you have the setting there in the PW dbx to choose the default wall to show in plan view. that is what determines the situation to appear, if you choose the upper as the default. Most likely the best answer, but still not sure. Link to comment Share on other sites More sharing options...
