Adding a garage from a different file..
wjmdes
Go to solution Solved by wjmdes,
Is there anyway to take a another design such as a unattached garage from a different CA file and add it to my main house plan?  I have a project where the existing garage is not at the same finished floor and at an odd angle to the home and makes it unsuitable on the same file, but would like for it to show in the 3D renderings...
Symbols have a 2D Block for the Plan View.  That's automatically created when the Symbol is created and will generally be a "Top View".
There are several ways to create additional 2D Blocks that could be substituted.  Once you create the additional 2D Blocks, store them in the Library so you can add them to any Plan and assign them to the Symbol in that Plan.
