Roof over door
ChiefRedskins
I'm only guessing where the door is and this is just a start, but select those 3 walls and make them invisible...or make the 2 side walls railing walls with post to beam...or just manually place the roof planes...
There are various methods.  It really depends on the specifics of exactly what you are trying to do.
Click on the roof plane tool and draw in a manual roof.  It helps if you create a cad line first with the exact distance you want the roof to extend.  Then you can create the manual roof plane from that line toward the house.  Stop the roof plane at the siding, not the framing.
