BlackLabelHQ Posted July 22, 2016 Share Posted July 22, 2016 On this plan, I have an upper false porch. I need to put railing between the posts on the roof overhang. It is not a true deck, so if I use the deck rail tool, it tries to create deck joists which I don't need. Any ideas? Putney Porch Re-build.planFetching info... Link to comment Share on other sites More sharing options...
BlackLabelHQ Posted July 23, 2016 Author Share Posted July 23, 2016 Thank you Eric. I've updated my signature. I have not found a way to change the forum for this post. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 23, 2016 Share Posted July 23, 2016 I would treat it just like a room called Balcony using railing walls (post to beam). That way it's included in Schedules and materials list. Link to comment Share on other sites More sharing options...
BlackLabelHQ Posted July 23, 2016 Author Share Posted July 23, 2016 Any idea why the first level deck is a generic lumber color when I have the room specification>structure>planks,joists set to a taupe deck plank? Shouldn't the perspective view of this porch deck and stairs match? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 23, 2016 Share Posted July 23, 2016 On 7/23/2016 at 5:59 PM, BlackLabelHQ said: Any idea why the first level deck is a generic lumber color when I have the room specification>structure>planks,joists set to a taupe deck plank? Shouldn't the perspective view of this porch deck and stairs match? You need to check "Automatically Regenerate Deck Framing" for that material to show. The deck surface is a unique surface in Chief as it is treated like a framing layer and must therefore be "framed". Link to comment Share on other sites More sharing options...
BlackLabelHQ Posted July 23, 2016 Author Share Posted July 23, 2016 Ahhh. Now that makes sense. Thank you Michael. Link to comment Share on other sites More sharing options...
BlackLabelHQ Posted July 23, 2016 Author Share Posted July 23, 2016 I originally created a room using invisible walls to create the space and the roof. For my purposes, using the symbol to create the rails works. I only need to create the elevations for this project. Link to comment Share on other sites More sharing options...
BlackLabelHQ Posted July 23, 2016 Author Share Posted July 23, 2016 Here is the structure I'm trying to replicate. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 24, 2016 Share Posted July 24, 2016 On 7/23/2016 at 7:01 PM, solver said: I tried that first, but was unable to get the railing to show. There was a deck room formed, but no visible rail. Someone please take a look. I do those using rooms all the time, must be a balcony room to do it this way. Did you use post to beam with a railing? Link to comment Share on other sites More sharing options...
