BlackLabelHQ
Decorative Railing for False Deck
On this plan, I have an upper false porch.  I need to put railing between the posts on the roof overhang. It is not a true deck, so if I use the deck rail tool, it tries to create deck joists which I don't need.  Any ideas?
Putney Porch Re-build.plan
I made a symbol from the 1st floor railing.
This should be posted in Q&A, as Tips & Techniques is for tips and techniques.
Also, please take a minute to fill out your signature with at least the Chief version you are using. A name would be nice too.  Click on your user name at the top right of the page, click My Settings, then Signature on the left.
Thank you Eric.  I've updated my signature.  I have not found a way to change the forum for this post.
I would treat it just like a room called Balcony using railing walls (post to beam). That way it's included in Schedules and materials list.
Any idea why the first level deck is a generic lumber color when I have the room specification>structure>planks,joists set to a taupe deck plank?  Shouldn't the perspective view of this porch deck and stairs match?
You need to check "Automatically Regenerate Deck Framing" for that material to show.  The deck surface is a unique surface in Chief as it is treated like a framing layer and must therefore be "framed".
I tried that first, but was unable to get the railing to show. There was a deck room formed, but no visible rail.
Someone please take a look.
I originally created a room using invisible walls to create the space and the roof.
For my purposes, using the symbol to create the rails works.  I only need to create the elevations for this project.
I do those using rooms all the time, must be a balcony room to do it this way. Did you use post to beam with a railing?
    27858
    danmor
    danmor
  • Similar Content
    • By Designer100
      Does anyone know why my pier and beam foundation floor joists and beams disappear when I try to do perpective and I have to back out of it? Open old one! I custom drawn floor joist and pads and 1 concrete block on each pad then drew beams and floor joists. I keep trying to pull siding down over to cover the beams and floor joists and then they all disappear. I need the floor decking to appear on a section over floor joist to with deck up level with entry and grass under home.
      I did this project in Chief x11. I would appreciate any help in this apartment.
      Thanks
      Newell Cheatheam
      Katy,Tx. 77450
      newell.cheatheam@gmail.com
      713.385.3622.
      Apartment_Plan.plan
    • By Designer100
      I have designed a pergola and a deck. I cannot get the terrian to show right. It needs to be zero of level at back of deck by pool deck and slowly slope down to a bayou. it needs to be 36" to grade at edge of outer deck Then a stair going down to the end of stair which is around 5 fr lower that top of deck. I have not did much terrian and would appreciate your help. This is just a remodeling and adding a deck from the pool.
      Thank  you,
      Nerwell
      Pergola_.plan
      11X17.layout
    • By DeckQuestions
      Is there a way to make the top rail of my deck railing rounded?
    • By ChiefArchitect
      Option 6 is large enough to provide extra family space in the form of a loft on the 2nd floor. For this house style, we put a balcony over the porch and front door, making this sunny room even more welcoming.
    • By Conserva
      So I've drawn up a deck on a second floor but the framing is showing up on the floor below. I feel like I am missing some small detail but I can't figure this one out.
