sfarekas
herringbone pattern - help please!
Hi all,
I'm new to Cheif architect, and hoping for a little help!
I'm trying to create a herringbone pattern on my kitchen backsplash.
I've already changed the pattern on the copy of a tile material from the core catalog, but it doen't show up in the 3d view or on the teapot as a herringbone pattern???!!!
am I doing something wrong? how do I get this herringbone effect?
Thanks,
Sima
CA X8
Sima,
The reason it's not showing up in the 3D view or on the teapot is because you need to change the texture material as well.
Changing the pattern style only will only show up in the "technical illustration" 3D view.
Sima,
Yep, except I would add that Patterns/Material Types are also used in Vector Views and Line Drawings as well.
Thanks David,
is there a way to get the herringbone pattern in texture material other than grabbing a picture?
I'm looking to change grout color or similar nuances for a better 3d view?
Thanks David,
At the moment I think grabbing a picture is the only way to set a custom texture to something. That being said, changing the grout color won't be possible unless you edit the initial picture first.
Not for the faint of heart but a person could use polyline solids or material regions to create the tiles or grout or both. It's not that bad if you're used to the process, but otherwise it can be pretty time-consuming. You can use distributed objects, multiple copy, and transform/replicate among other things to speed the process up but it definitely takes a little work no matter what you do. Cool thing is that you can create some very unique and realistic tile layouts with the ability to quickly change tile and/or grout colors on an item by item basis.
thanks guys, I was trying to avoid all the extra pre work, or polyline solids creation; but you answered my question.
I'm surprised there aren't options for layout in addition to angled, like herringbone, and basketweave...they've always been pretty common...
Thanks for all the help
    27483
    Reboreb
    Reboreb
  • Similar Content
    • By robdyck
      Is there still no material that will allow transparency in Vector View? I use a lot of glass for deck railings and its completely insane what needs to be done to make an exterior elevation drawing look decent. Currently, I need to build my railings without any glass, then build the glass manually, place on a separate layer so I can have it on in renderings, but off in elevation views (vector). Then, in elevation view, I need (choose) to manually draw p-lines with transparent fill to show the glass without blocking visibility of the structure beyond.
      I don't like fighting Chief's defaults and auto features, but I also want my drawings to have a certain appearance. Anyone have any thoughts or tips for transparent glass (not windows) in vector views?
    • By Luciano
      Hi everyone,
      Is it possible to create more then one new material at the time?
      I have in a folder filled with wood grain pictures (vertical & horizontal) and I would like to add them all to my library but doing it one by one will take forever... From what I see in the program, there doesn't seem to be a way yet. But I imagine or hope that someone found a way to do it.  I must not be the first user who wants to do that to save time. Any idea everyone?  Thank you.
    • By ginamk
      Hi,
      I'm having an issue with X9 - anytime I open an item and try to change the material type, I get a pop-up box that says "searching for files" and it appears to be searching through my file folders, but it's on a continuous loop searching the same folder endlessly so the search message isn't going away and I have to force stop the program. I've tried opening different files to see if it was just happening with a possibly corrupt file, but it's happening with several different files so I don't think thats it. I called the help line and they are not familiar with the problem. They said I should try my luck here.
      Anyone have this problem?
    • By DonSpring
      How do I take picure of a color or texture and use it in Room Planner as a custom material?
    • By NewAsia
      Hello,
      I'm using Chief Architect Premier X9 ( Version 19.3.1.8)
      I cannot see any texture in my standard camera views and overviews.
      I tried to in-install and re-install the software but it didn't work. How can I solve this problem?
      Thank you,
