dnpayne Posted May 21, 2014 Share Posted May 21, 2014 I have a room above my garage. Currently the walls are the same default size as the rest of the floor. I want to shorten the left and right wall to bring the roof life down. This should cause the corners of the room to cut into the roof line. How can I go about doing this? The only way I can seem to move the wall height is change the ceiling. I don't want to do that because the ceiling is the same throughout the floor. I just need the walls to drop down roughly 18in or so. this room is vaulted.Any help? Link to comment Share on other sites More sharing options...
jbaehmer Posted May 21, 2014 Share Posted May 21, 2014 I believe this is what you are wanting to do. By using your roof planes baseline height, you can change the height of the walls for your second story. Take a cross section of the attached plan. Hope that helps. Untitled 1.plan Link to comment Share on other sites More sharing options...
dshall Posted May 21, 2014 Share Posted May 21, 2014 I believe this is what you are wanting to do. By using your roof planes baseline height, you can change the height of the walls for your second story. Take a cross section of the attached plan. Hope that helps. Such a great lesson from Jay. Think about it, you asked how to drop the height of the walls, if you dropped wall height what do you think would happen to roof? Yes, drop the roof 24" and that changes wall height. IOW, roof controls wall height, not vice versa. Link to comment Share on other sites More sharing options...
jbaehmer Posted May 21, 2014 Share Posted May 21, 2014 Thanks....for some reason I had a hard time putting it in words that made sense...hence why I posted the plan. Link to comment Share on other sites More sharing options...
dnpayne Posted May 22, 2014 Author Share Posted May 22, 2014 Perfect! This is exactly what I needed. Thanks. Link to comment Share on other sites More sharing options...
