Rough Bucks in unframed Walls?
Joe_Carrick
How can I get Windows and Doors to show the rough bucks needed in unframed (masonry, concrete, SIP) walls?  Do I need to create a symbol for each of them with those as a part of the symbol?
Basically, I just want to make sure the openings will be the right size, allowing for a rough buck and a shim space.  I would also like the rough buck to show in a 3D view with the Windows and Doors suppressed.
A little bit of a hassle, but one thing you could do is use a doorway/pass through the size of your RO and then add a standard framed no room def wall resized in elevation to fit inside that pass through. Your door would be placed into the no room def wall.
