Move wall - tab
johnny
Johnny,
When you drag the wall, and hit Tab, I think you will see that the Angle has changed (because of how you dragged the cursor?).
So you need to specify the angle (180deg in this case) as well as the distance.
I assume that you have Orthogonal set as your Primary Movement Method which is restricting the movement of the polygon to up and down (Orthogonal), even though your cursor is sliding sideways as well as down.
Walls work a bit differently
The resolution of your vid makes it hard to see, but I am pretty sure that's what is happening.
