Griffin Posted June 25, 2016 Share Posted June 25, 2016 The print preview looks fine, but when I print to a PDF I loose resolution in part of the layout page. Referring to the first attached image, the upper half of the print has faded lines. I have tried Adobe PDF, CuteWriter, and Nitro all of which show the same problem, and all look fine in print preview. The second image is the PDF NOT sent to Layout, just printed as a page view and this looks just like the preview image. Does anyone have an insight about what might be causing this or had a similar problem? Link to comment Share on other sites More sharing options...
Solution Griffin Posted June 25, 2016 Author Solution Share Posted June 25, 2016 Spent a couple of hours on this - only to be resolved by deleting that particular layer set and creating a new one. There might be a bug in Layout somewhere as I could not find the single offending layer that masked the plan. I was able to move the masking anomaly around the page by using different layer configurations, but the problem remained. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 26, 2016 Share Posted June 26, 2016 I also see this but It seems to print ok, not sure why. also when you zoom in it looks ok. Link to comment Share on other sites More sharing options...
