mlgallant Posted June 21, 2016 Share Posted June 21, 2016 Does anyone know if a compatible file can be exported from HSBCAD/AutoDesk that can be imported into Chief X8 to create 3D renderings? I have a log home builder client who would like 3D renderings of their floor plans. Thanks Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 21, 2016 Share Posted June 21, 2016 They should be able to export a DWG, a 3D DWG, 3DS, etc. The bigger problem though is material definitions. You would probably need to run it through a separate program (like Sketchup maybe) in order to assign materials to the various surfaces. Link to comment Share on other sites More sharing options...
KevinWaldron Posted June 21, 2016 Share Posted June 21, 2016 Better served in my humble opinion using another program. Something like Simlab Composer Pro .... it would be much faster and easier and would look more realistic. kevin Link to comment Share on other sites More sharing options...
Solution mlgallant Posted June 22, 2016 Author Solution Share Posted June 22, 2016 Thanks for your advice. I think I need to pass on this project. Link to comment Share on other sites More sharing options...
