Designer100 Posted June 15, 2016 Share Posted June 15, 2016 Exterior Rear Elevation (left) is showing stone columns stopping at 2nd level btm of deck then from deck to top of eave. I need it continuous. need sloped clg at 2nd floor veranda. Chief x8 any help would be appreciated. Rod Home 5-13-16.zip Link to comment Share on other sites More sharing options...
justmejerry Posted June 15, 2016 Share Posted June 15, 2016 For your columns delete top ones and set the height of bottom ones to what you had for the top ones and they will be one continuous column. For the sloped ceiling uncheck has ceiling in room structure dbx. Alternative if you don't want ceiling on underside of roof would be to put two ceiling planes over veranda. Link to comment Share on other sites More sharing options...
Designer100 Posted June 17, 2016 Author Share Posted June 17, 2016 Thank you for help. Link to comment Share on other sites More sharing options...
