morkas Posted June 11, 2016 Share Posted June 11, 2016 I've been in HDA 2012 and prior until tonight when I upgraded to CAPX8. There will obviously be a learning curve. I must have clicked something while rebuilding my roof because the rafters show in my floor plan view. Please help! I can't work in the file with this distraction. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 11, 2016 Share Posted June 11, 2016 All objects are on "Named Layers" found alphabetically in "Display Options". A "Display Options" dialog exists differently in: Plan view, and each Camera Type you use so that means " Framing, Roof Rafters" can show or not show depending upon how it is set in the Several "Display Options" dialogs. DJP 1 Link to comment Share on other sites More sharing options...
morkas Posted June 11, 2016 Author Share Posted June 11, 2016 Thank you so much! I had explored this last night, but I guess not extensively enough. I make it a practice to try to exhaust my search through the software, manuals, and forums before I ever ask a question, but sometimes the answer is right in front of you and you don't even see it because you have been looking at it for too long. Thanks Eric and David for gently pointing me in the right direction. Link to comment Share on other sites More sharing options...
