4hotshoez Posted May 23, 2016 Share Posted May 23, 2016 File is 14,449 KB. I also have friezes vanishing for no apparent reason. Such as on the back of the garage were the foundation and wall the roof sets on are both simple, single walls. Yet randomly the frieze stops and starts. It is hard to keep up on all of the anomalies that Chief creates, which is why there is such a steep learning curve after learning the basics. 1505T21.zip Link to comment Share on other sites More sharing options...
Solution johnny Posted May 23, 2016 Solution Share Posted May 23, 2016 I do wish we had a better way to manually select connections between walls/roofs etc. However, it is a quick fix in the current system: (by the way nice house design - is this a new construction or existing remodel of an English tutor?) Link to comment Share on other sites More sharing options...
4hotshoez Posted May 23, 2016 Author Share Posted May 23, 2016 Thanks Johnny, That was easy. I do that on the exterior regularly. I did not recognize it as the same problem since the wall looked so wacky. The house is all new construction. It started out as a "modern-farm house" as the client wanted, but they bought a lot in a neighbor hood that required an older, up-scaled style.I had to simplify the design a little due to budget. Link to comment Share on other sites More sharing options...
