Selection productivity
FelthamUK
By default, the Esc key will cancel the current command and selection and make the previous command current.
Another Esc will go back one more previous command...etc, up to 100 previous commands (is that enough?)
If you look at the status bar it will indicate the current tool as you press Esc and cycle back through the command list
There are separate tools for Next Command that cycles forward through the command list (default shortcut is Shift+Esc), and you can have separate commands for  Cancel Selection and Previous Command by assigning hotkeys to those commands.
These commands aren't on a menu and don't have toolbar buttons - they can only be used with hotkeys and the only commands that come with hotkeys already assigned are Cancel Selection/Previous command (Esc) and Next Command (Shift+Esc).
For the others (Previous Command and Cancel Selection) you will have to assign your own hotkeys.
I think you are out of luck with "select previous objects".
  • Upvote 2
