IvanCyr
Show short wall to butt against longer wall in plan view.
Hi,
This is likely a real amateur question, but I was wondering how one can show in plan view how two shorter walls of a rectangular room butt against the longer walls of the same rectangular room?  I've tried to color the two walls differently using a "copy" of the wall and it was the longer walls that show butted against the shorter.  I just need the opposite to happen.  Open to ideas.
Thanks in advance.
Ivan
There are 2 things you can do that come to mind...
1.  Select the longer walls and on the structure tab, check "Through Wall At Start" and "Through Wall At End".
2.  Select one of the walls and then click on the Edit Wall Layer Intersections tool in the Edit toolbar.  This will allow you to select the wall's main layer (as well as any other layer you wish) and move it accordingly.
Ah....that will be a tip to remember for the future!  Thx so much Michael!
 You are very welcome : )
    28901
    Heizen
    Heizen
