DCaplan Posted April 6, 2016 Share Posted April 6, 2016 I am trying to figure out why my walls are not going to the peak, any insight into why this might be occurring? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 6, 2016 Share Posted April 6, 2016 Wall edges are defined by what is called a "Wall poly line". When selected the wall poly line will show "handles" that can be edited and to reshape the wall. You use this to fill any holes or anomalies like what you are showing. Another way is to go to the "Attic Level" (<A>) of your model and then manually draw in the missing attic wall segments. Whenever something is wrong there is always something you can do about it. DJP Link to comment Share on other sites More sharing options...
DCaplan Posted April 6, 2016 Author Share Posted April 6, 2016 Thank you David, that worked perfect. I appreciate your assistance. Link to comment Share on other sites More sharing options...
