Wall/moldings
johnny
Is there a way to turn off moldings on a certain wall?...or do I need to set the entire room no moldings and place a modeling poly?
If it doesn't exist, I would be nice to have a checkbox on the wall Dbx for "no molding" on that wall.
Select the room and click the Make Room Molding Polyline tool.  Then you have an automatically created molding polyline you can edit however you want.
P.S.  I noticed you sent me a P.M.  I'll check it out in a bit here.
And once you've done this, you can select your molding polyline and you'll get a tool in the toolbar at the bottom that switches between "Remove Molding from Selected Edge" and "Add Molding to Selected Edge," depending on which polyline segment you have selected. It's the very last icon, which makes it easy to find as you're editing the polyline.
