skirby19 Posted March 11, 2016 Share Posted March 11, 2016 I've been attempting to build some custom raftertails. Client has sent me a design i'm trying to mimic. What is the best approach? is there a design in the library that is similar? so I don't have to create it from scratch. I have open rafters and I would need the attached design for every other raftertail. RAFTER DESIGN.pdf sommers 3.plan Link to comment Share on other sites More sharing options...
skirby19 Posted March 11, 2016 Author Share Posted March 11, 2016 Here is an elevation view of the sample design he sent showing the rafters. RAFTER DESIGN2.pdf Link to comment Share on other sites More sharing options...
MPDesign Posted March 11, 2016 Share Posted March 11, 2016 Skirby Here is a copy of your plan. Look inside to see how it was made. Also the numbers in the sketch were off a little. and the pitch on the model is 6-12 so adapted to that pitch. hth, sommers 3-FIX.plan Link to comment Share on other sites More sharing options...
skirby19 Posted March 11, 2016 Author Share Posted March 11, 2016 wow. thank you so much. I will study this. looks perfect. Link to comment Share on other sites More sharing options...
