Terrain against house perimeter
Nicinus
Go to solution Solved by KilgoreTrout,
  • Solution
If you turn off "hide terrain intersecting building", then your terrain will go through your foundation walls.  This may not be a problem in the plan you are working in, but if you had a basement then it would be a problem.  When I run into these problems, I manually create my own hole in the terrain.  I start with the room polyline for the exterior room, modify the shape as needed, and then convert it into a terrain hole.
I didn't realize that, which doesn't sound like a good thing. I see it both in cross section and camera looking down a stair case. I will try creating the whole manually instead then. This can't be by design so I assume it is a bug. Should I report it or is there a list of known bugs?
