Hole in kitchen cabinet
ldharris
I'm attempting to add a hole in a kitchen cabinet to place a sink. But for some odd reason it won't add. Is there something different that I have missed in X6. I had no problem doing this in all the earlier versions. What am I missing?
Thanks,
 Larry D
If you are trying to draw your own hole using the custom counter top hole tool, you can only add it to a custom counter top, not to an automatic one.  As Joe pointed out, you should automatically get a hole for your sink if you are using one of the library sinks.  If you have made your own sink and need a different hole, you need to put the hole in the cad block for the sink.
