Problem Recessed Entry In Commercial
Greg_B
Go to solution Solved by rlackore,
I can't figure out how to do a recessed entry in a commercial building. Considered making part of the building two storey but that seems wrong. Here is a rough idea of the concept showing a view from outside the building and one from the inside. Of course, there would be a door in the glass panel area. Also does anyone know where there is a Library of standard commercial door/window items?
CA X6 BTW. I see all my history and signature containing my info is missing.
  • Solution
Just draw the walls to create the vestibule:
...then plop in the windows and doors (nothing useful in the Library - you'll have to roll your own):
...you get this:
...here's a quick section through the vestibule - mezzanine above (created as a second floor):
Commercial in Chief isn't always easy, but most of it can be accomplished.
