Razorback1 Posted January 31, 2016 Share Posted January 31, 2016 I have drawn a simple bathroom and added 2 niches, but can not get them to fill in for a solid back. What am I doing wrong ? I have attached the plan for reviews. I researched it in the reference manual, and it describes to select build, primitive, solid polyline, But this does not work. Any suggestions ? Thanks, Dale Ancich Bathroom 2.planFetching info... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 31, 2016 Share Posted January 31, 2016 Dale, See this thread https://chieftalk.chiefarchitect.com/index.php?/topic/4413-wall-niches-library-revised/?hl=niche for some symbols that work. You can change the materials to suit your needs. Link to comment Share on other sites More sharing options...
Razorback1 Posted January 31, 2016 Author Share Posted January 31, 2016 Joe Thank you, great download. The niche with out frame is exactly what I was looking for. One question, Can I place the niche after I have tile material on wet wall, Or do I need to place it prior to placing wall material ? Dale Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 31, 2016 Share Posted January 31, 2016 Dale, Place the wall material first. The symbols are designed to cut the wall material. Link to comment Share on other sites More sharing options...
Razorback1 Posted February 1, 2016 Author Share Posted February 1, 2016 Joe, one thing I have noticed is in 3D view the niche extends about 1/2 inch off the wall surface, and does not fit flush to the wall. ? Am I missing a step when placing the niche. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 1, 2016 Share Posted February 1, 2016 Dale, Do you have a "Wall Material Region"? That could be the cause - but I'm not sure. IAE, you can open the Symbol dbx and adjust the 3D y-origin 1/2". I'm not sure if it should be + or - but that will move it relative to the wall face. Link to comment Share on other sites More sharing options...
