I recently upgraded to X7 and I can't get any of the 3D views to work. When I select to show a 3D view it is just shows a white screen.  Also when I place a window and double click on it to change the windows specs I don't see the window
Make sure the layers you want to see are turned on.
If you are using Windows, check to make sure Chief is using the correct graphics card.  I had that problem when I switched to windows 10.  I have a laptop and windows 10 reverted back to the onboard intel graphics card to save battery power.  Right click on desktop to get to the graphics settings and set quality to max and that Chief is designated as using the right card.  This is all assuming that you have an external graphics card.
    27617
    zzubin
    zzubin
