Need Help With Retaining Walls.
HaywardVT
1. The foundation wall that is part of the basement and connects the retaining walls doesn't reach the bottom of the floor above it and I can't figure out a way to close the gap.
2. The basement and retaining walls are set to be the same height but they aren't, the retaining walls sit higher up. Both stem walls start at the absolute elevations (B) of -10" and the relative heights (I) are 98.5"
PAPP dormer work.plan
If settings "fail" then you can always manually adjust the wall poly-lines so they will match. This is best done in a cross section camera for finer control. In the final analysis, it is you who is in control and only you who is responsible for outcomes, just make it happen by whatever means.
