ACADuser Posted December 16, 2015 Share Posted December 16, 2015 I need to add ADA railing to steps with hand rails, steps with cable railing & ramps with & without railings. What is the best tool for this? Some straight but most sloped at varying angles. Link to comment Share on other sites More sharing options...
johnny Posted December 16, 2015 Share Posted December 16, 2015 You best bet is probably to use a molding poly - but someone may have a better solution. Link to comment Share on other sites More sharing options...
Bill_Emery Posted December 16, 2015 Share Posted December 16, 2015 The attached screenshot is two 3D polyline moldings butted together. I tried it with a single 3D molding polyline; but Chief got very confused. Prpbably best to work in two axis for each segment. Once you have what you want, convert it to a symbol. Link to comment Share on other sites More sharing options...
ACADuser Posted December 16, 2015 Author Share Posted December 16, 2015 Bill, that's pretty good. Did you draw one in elevation view & the other in plan view? Link to comment Share on other sites More sharing options...
Bill_Emery Posted December 16, 2015 Share Posted December 16, 2015 Yes, Chief gets very confused if you use all three axis. Link to comment Share on other sites More sharing options...
