mbblakesley Posted December 8, 2015 Share Posted December 8, 2015 Really silly question but when stacking an awning over a casement, the horz casing between the windows won't go away to allow the two to mull. I just want casing around the pair of windows, just as it does when they are joined side by side. What am I missing? Thanks Link to comment Share on other sites More sharing options...
Solution MPDesign Posted December 8, 2015 Solution Share Posted December 8, 2015 First adjust the window default setting to bump at 0. At the bottom of the window default dbx. Make sure your bumping and pushing are turned on, move them together. Select first window, hold shift key and select 2nd unit, click make block tool. Link to comment Share on other sites More sharing options...
mbblakesley Posted December 10, 2015 Author Share Posted December 10, 2015 There's the magic I was looking for.........Select first window, hold shift key and select 2nd unit, click make block tool. Thanks a lot! Link to comment Share on other sites More sharing options...
