Ceiling Heights May Not Be Change: Varying Heights On Floor Above.
HaywardVT
Well, after I did the no room def trick the problem wasn't solved, came here and made the last post, then went back to CA and I was finally able to change the ceiling heights. Maybe the no room def trick works, but I didn't do anything else to fix the problem when it still wasn't letting me change the heights after I tried it.
