moulding wall issue
Designer100
Because you have not attached a plan, this is just a guess, but I am assuming you expected the moulding to go to the top of the wall but "to top" is setting the moulding in relation to your moulding p-line...not the wall. To get that moulding to the top of the wall you would have to adjust the height of the moulding p-line...or offset the moulding by the height of the wall. In other words, if you have a 96" tall wall, you could either set the moulding p-line at 96" and set the moulding at 0" "to top" or you could set the moulding p-line at 0" and set the moulding to 96" "to top".
