gelbuilding Posted September 8, 2015 Share Posted September 8, 2015 After sending elevations on the layout everything fine except when i send the wall details, ie the framing, i see that the framing wall is flipped around the other way. (see attached Pic) Any idea how to fix? I cannot work the way to get the correct view for the framing. Link to comment Share on other sites More sharing options...
dshall Posted September 8, 2015 Share Posted September 8, 2015 There is a default somewhere that lets you look at framing from inside and not outside. Probably in framing defaults. Link to comment Share on other sites More sharing options...
dshall Posted September 8, 2015 Share Posted September 8, 2015 Or try flipping wall and then do framing. Link to comment Share on other sites More sharing options...
gelbuilding Posted September 8, 2015 Author Share Posted September 8, 2015 Thanks Scott, In framing defaults in the wall tab, at the bottom is states Build Wall Framing Details from exterior. Excellent. Scott, One more thing if you can help, See the bathroom wall where the door is, i broke the wall into three sections, because of my wall linings. Wall Detail 29 is Sheetrock both sides, Wall Detail 19 Is Sheetrock with villa board and tiles the other side and Wall Detail 20 is villa board one side and the other villa and tiles. Is there a way to send to layout in one piece, i.e. the three walls as one. Because im sure my carpenter will get confused. Also i cannot find the layer to turn on to show where i broke the wall, i think i might have to draw in manually, Or is there a way because i don't see it in the layers. Link to comment Share on other sites More sharing options...
dshall Posted September 8, 2015 Share Posted September 8, 2015 Thanks Scott, In framing defaults in the wall tab, at the bottom is states Build Wall Framing Details from exterior. Excellent. Scott, One more thing if you can help, See the bathroom wall where the door is, i broke the wall into three sections, because of my wall linings. Wall Detail 29 is Sheetrock both sides, Wall Detail 19 Is Sheetrock with villa board and tiles the other side and Wall Detail 20 is villa board one side and the other villa and tiles. Is there a way to send to layout in one piece, i.e. the three walls as one. Because im sure my carpenter will get confused. Also i cannot find the layer to turn on to show where i broke the wall, i think i might have to draw in manually, Or is there a way because i don't see it in the layers. It must be one wall. Wall framing is on per wall basis. So use one wall and then use wall material regions for different materials? Link to comment Share on other sites More sharing options...
gelbuilding Posted September 8, 2015 Author Share Posted September 8, 2015 Good Idea, Thanks Scott Link to comment Share on other sites More sharing options...
gelbuilding Posted September 8, 2015 Author Share Posted September 8, 2015 Scott, believe i didn't even know about this tool. Saved me a lot of work Thanks again Link to comment Share on other sites More sharing options...
