jim3552 Posted July 24, 2015 Share Posted July 24, 2015 I need to be able to draw a cathedral style ceiling, but offset from the center. Essentially this is a saltbox style roof, but with no second floor. One exterior support wall is several feet higher than the other. Any ideas? I can draw the structure using a hip wall on the second floor, but I want the ceiling to be the roof thanks Link to comment Share on other sites More sharing options...
johnny Posted July 25, 2015 Share Posted July 25, 2015 This is actually very easy to do and I think there is a video in the library on this subject. If you set the baseline of the roof plane at the elevation you need the lower wall on the rear side of the home should auto-generate to that point. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted July 25, 2015 Share Posted July 25, 2015 Is this what you are looking for? This was done by making both end walls Gable Walls. Use 2 manual roof planes with identical locked ridge heights and 2 different eave heights. In this case I used a 4 x 12 ridge beam and 4 x 6 rafters. Remove the room ceiling and change the roof sheathing material to tongue & groove. Link to comment Share on other sites More sharing options...
