Sign in to follow this
RobUSMC
Wall Dimensions BOTH SIDES
Does anybody know the settings so when you select a wall such as an angled wall it will show the dimensions for both sides of the wall?  I would not only like to see the outside corner to corner dimensions but the inside as well.  Ive tried to click on the inner most part of the wall but keep getting the dimensions for the other side of the wall.  See attached.
Thanks
Rob
The only way I know to make this work is to reverse the wall direction.
Kind of a pain to flip every wall while drawing as they don't line up with any previously drawn wall. Like a bay window in a master bath remodel. I measure the inside corner to corner, etc. and are the measurements I would like to use drawing.  Flipping the walls by reversing the Start & End seems to work but having to flip each wall just adds to time and frustration.  Would love to figure out how to see a wall dimension for either side and adjust the length based on one wall side or the other
    27461
    WaunakeeDesigner
    WaunakeeDesigner
