RobertGHess Posted July 12, 2015 Share Posted July 12, 2015 I have been thru a number of videos and I can not find anything about rooms that have had walls removed(demo. layer turned off) but will not create a whole room after the walls are removed. I'm sure there is a simple answer, but I have spent literally hours trying to fix, rectify, erase, whatever to create a room from where I have demolished/removed existing walls. Any help would be appreciated. Robert Link to comment Share on other sites More sharing options...
country Posted July 12, 2015 Share Posted July 12, 2015 Use room dividers or invisible walls. Link to comment Share on other sites More sharing options...
DianneDSC Posted July 13, 2015 Share Posted July 13, 2015 Select the demo wall, open the dbx, set wall as non-room defining. Link to comment Share on other sites More sharing options...
tommy1 Posted July 13, 2015 Share Posted July 13, 2015 It sounds like you're going to do an existing/demo plan and the proposed plan in the same file. I personally don't advocate doing it this way. In a very simple model, you might be able to by doing this, but in a real complicated plan, you're bound to have troubles eventually. Just my opinion. Link to comment Share on other sites More sharing options...
