RobUSMC Posted June 24, 2015 Share Posted June 24, 2015 Does anyone know what setting to change so when you select a wall it will show the dimensions on the interior not the exterior. Or with an interior wall with angles to show measurements on either side. See the attached screen prints. Thanks Rob Link to comment Share on other sites More sharing options...
glennw Posted June 24, 2015 Share Posted June 24, 2015 Rob, I assume that you are talking about Temporary dimensions. Alt+Q (General Wall Defaults). Check Inner Surface for the angled wall and the one at bottom left. Check Outer Surface for the one at top left and the pic on the right. The dimension lines may be on the wrong side of the wall, but the extension lines will dimension to where you want. Link to comment Share on other sites More sharing options...
