domhchief Posted June 17, 2015 Share Posted June 17, 2015 Hello Chief Users, I am running Chief Version 10. I'm having an issue with a file I created last December. I can draw walls and change the floor plan without a problem but when I try and look at the elevation the program freezes up to the point where I have to shut down Chief entirely. I have tried to save the file to a couple different names and I am still having the same issue no matter what file I use. Any thoughts or ideas on how I can get the file to be workable again? I am trying to avoid having to re draw the model all over again. I am not having an issue with other files I am currently using. Any help would be greatly appreciated. Thanks, domhchief Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 17, 2015 Share Posted June 17, 2015 Try attaching the plan and we may be able to help you. It sounds like a hardware issue to me though. Link to comment Share on other sites More sharing options...
Doug_Park Posted June 17, 2015 Share Posted June 17, 2015 A shot in the dark here is that you are running a Vista or newer OS and are not running version 10 in XP compatibility mode. Full support for Modern post Vista operating systems started with X2. Link to comment Share on other sites More sharing options...
