DrafterMD Posted June 11, 2015 Share Posted June 11, 2015 Hello, I am trying to raise the height of my roof by 12" using the Translate/Replicate command. After raising the Z axis by 12" , my wall covering changed and my windows dissappeared or covered. Only the Trims shows up in perspective view. I Appreciate any help on this-- Thank you Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 11, 2015 Share Posted June 11, 2015 If you manually open the roof plane DBX and lock pitch then adjust the baseline height by the reqd amount. can do all roof plane at same time if they have same base line, or can also adjust fascia top as another option. but lock pitch first. Link to comment Share on other sites More sharing options...
DrafterMD Posted June 11, 2015 Author Share Posted June 11, 2015 Thank you so much Graeme Link to comment Share on other sites More sharing options...
