Changing Roof Heights
Walleye
Go to solution Solved by DRAWZILLA,
Quick question.
Using Chief Architect x7 and I set the ceiling height for rooms then build the roof.
Next, I need to change height of different roofs just to see what looks best. If I go into the different rooms and change the ceiling height, It doesn't seem to update the roof and raise or lower it.
Do I need to re draw the roof planes each time I change the ceiling height?
  • Solution
Roof will not update in that situation unless you have auto roof turned on.   Sometimes you have to use the " transform -replicate" tool to do it manually in the "z" direction.
