winterdd Posted November 7 Share Posted November 7 I noticed a while back when I "update all views" my elevations don't update. If I add text callouts or story poles they update but any changes in structure itself does not. I have been having to manually click the viewport in the layout and manually click "update view. Is there a fix for this? I trusted the update all views since x10 and luckily caught this error in x17 a while back. It makes me an easy target of sending out drawings that are incorrect after I revise the home if I am not careful. Link to comment Share on other sites More sharing options...
CarrieS Posted November 9 Share Posted November 9 Live views will always update when "Update all Views" is clicked. They will also always update before printing. However, Plot Line views will not. Plot line views have an added functionality with "Edit Layout Lines" that if we were to update it would erase any lines edited with that tool. We could probably do a better job there and I'll log the request. Are you using Plot Lines or Live Views for the views that aren't updating? Link to comment Share on other sites More sharing options...
winterdd Posted November 10 Author Share Posted November 10 22 hours ago, CarrieS said: Live views will always update when "Update all Views" is clicked. They will also always update before printing. However, Plot Line views will not. Plot line views have an added functionality with "Edit Layout Lines" that if we were to update it would erase any lines edited with that tool. We could probably do a better job there and I'll log the request. Are you using Plot Lines or Live Views for the views that aren't updating? I always use live views and never plot lines. Thanks! Link to comment Share on other sites More sharing options...
CarrieS Posted November 10 Share Posted November 10 If you're using live views then I recommend sending your project into Technical Support so we can take a closer look at the reason why they're not updating. Live views should update, that is their whole purpose Link to comment Share on other sites More sharing options...
