ChristianA Posted Thursday at 05:47 PM Share Posted Thursday at 05:47 PM (edited) Is there any way to have the bottom of a railing wall follow the bottom of the stair? I have a builder that frequently designs closed stringer stairs that are fully self supporting. The railing is built on top of a beam that sits next to the end stringer of the stair. Edited Friday at 04:24 PM by ChristianA Link to comment Share on other sites More sharing options...
PitMan71 Posted Friday at 02:26 PM Share Posted Friday at 02:26 PM Open the dbx of the stair and try selecting a closed stringer on the "Stringers" panel to see if that's the look you are trying to accomplish. Link to comment Share on other sites More sharing options...
ChristianA Posted Friday at 04:08 PM Author Share Posted Friday at 04:08 PM (edited) I'm sorry, I probably wasn't very clear on the initial post. The stair is already set up the way. The problem is that the railing is outboard of that stringer. When I offset the railing, it just floats with nothing below it. Here's an example of an old project where this was done in different software. Closed stringer stair with railing built outboard. An here is an example of another project completed. Edited Friday at 04:25 PM by ChristianA Link to comment Share on other sites More sharing options...
JonathanK Posted Friday at 05:48 PM Share Posted Friday at 05:48 PM You mean something like this? Link to comment Share on other sites More sharing options...
ChristianA Posted Friday at 05:51 PM Author Share Posted Friday at 05:51 PM Yes, that's exactly what I mean. But if you are just widening the outside stringers, I tried that, and I found that it looks weird in plan view (CA doesn't show the stringer). Link to comment Share on other sites More sharing options...
JonathanK Posted Friday at 05:56 PM Share Posted Friday at 05:56 PM I have all my stringers and newels, etc.. turned off in plan view...so I didn't notice. Here's a snip on what they look like turned on. I guess I don't know what look you're going for, but looks ok to me. Link to comment Share on other sites More sharing options...
JonathanK Posted Friday at 06:01 PM Share Posted Friday at 06:01 PM There is a layer called "Stairs & Ramps, Stringers". Make sure that's turned on. Then turn on "Draw Newels" and "Draw Rails" in your stair specifications DBX. It's under the "Newels/Balusters" section. Link to comment Share on other sites More sharing options...
ChristianA Posted Friday at 06:15 PM Author Share Posted Friday at 06:15 PM I will check it out. Thanks so much for the guidance! 1 Link to comment Share on other sites More sharing options...
ChristianA Posted Friday at 09:08 PM Author Share Posted Friday at 09:08 PM Jonathan, I ended up making it work. I had no idea that layer existed. Thank you so much! 1 Link to comment Share on other sites More sharing options...
JonathanK Posted Friday at 09:54 PM Share Posted Friday at 09:54 PM You betcha. Glad to help! Link to comment Share on other sites More sharing options...
