LotzCC Posted Thursday at 04:32 PM Share Posted Thursday at 04:32 PM Is there a quick way to change multiple light fixtures to a different light fixture? I have tried using the object eyedropper to change several bare bulb fixtures to recessed, but the symbols do not match the object I am sampling. Link to comment Share on other sites More sharing options...
DBCooper Posted Thursday at 05:52 PM Share Posted Thursday at 05:52 PM Have you tried using the "replace from library" tool? Just select one of the lights and then click on the tool. You can then pick the light you want to replace it with and if you then chose "replace identical objects on floor" it should replace all of them at once. 1 Link to comment Share on other sites More sharing options...
