Litsinger Posted 21 hours ago Share Posted 21 hours ago First time visitor to the forum. Novice user of Chief Architect, but have had a bit of experience in working with other 3D modeling software. Hopeful someone can give me some pointers concerning best practice for trimming out overbuild when joining two roof sections together that are running perpendicular to one another. Trying to create a bonus area in the rafter space above a ceiling and haven't managed to figure out how to remove the extraneous roof where the North - South section intersects with the East-West section. Thank you for help and feedback. I appreciate it! Russ p.s. I attempted to search this question up in the forum but could not find where it had previously been addressed - if it has and I missed it, my apologies for the duplicate thread. Link to comment Share on other sites More sharing options...
Mark3D Posted 15 hours ago Share Posted 15 hours ago (edited) See if that video gives you what you need Edited 15 hours ago by Mark3D 2 Link to comment Share on other sites More sharing options...
Litsinger Posted 9 hours ago Author Share Posted 9 hours ago (edited) Mark: Thank you kindly for your very helpful reply. I sincerely appreciate it. When using the 'Auto Roof' function, is there an easy way to pre-define the gable orientations? When I auto create a roof for the section in question., I get the following result - and while I can relatively easily address the North-South gable configuration, the East-West configuration proves a challenge because the valley is pre-cut and I cannot 'square-up' the portion automatically cut to align with the North-facing gable. For reference, South in this model is the long end facing the two story portion. I've tried removing the section, spinning it 180 degrees and re-attaching, but this creates more problems than it solves. Thanks again for your feedback. Russ Edited 8 hours ago by Litsinger Link to comment Share on other sites More sharing options...
Mark3D Posted 4 hours ago Share Posted 4 hours ago Chief architect has lots of training videos you need to watch them they are really helpful if your ssa is not upto date there is a lot on you tube as roofs can be tricky at first The walls you want to be gable, select the wall turn on gable with its toolbar also you can open the wall go to roof tab and set as gable. Link to comment Share on other sites More sharing options...
