mpaska Posted 15 hours ago Share Posted 15 hours ago (edited) I am trying to replicate this real world example; where the step down area is just inside the walls. So that the framing bottom plate always sits on the same slab level as the rest of the slab. I've tried: If I set floor to a negative value, it also moves the framing down. Placing a "slab hole" - this doesn't appear to work with monolithic slabs. Any suggestions on how to archive this? Edited 15 hours ago by mpaska Link to comment Share on other sites More sharing options...
Solution GeneDavis Posted 15 hours ago Solution Share Posted 15 hours ago From AI: To create a lowered or sunken shower in a slab foundation using Chief Architect, you will need to define the shower area as a separate, distinct "Room" using the Room Divider tool, and then adjust its floor height on the structure settings. 1 Link to comment Share on other sites More sharing options...
mpaska Posted 15 hours ago Author Share Posted 15 hours ago Thank you! That did it. Hah, I'd asked Claude myself as-well before posting and it sent me down a rabbit hole of slab/foundation editing. Link to comment Share on other sites More sharing options...
