Chief-007 Posted 2 hours ago Share Posted 2 hours ago Hello, I am in Chief x17. I’m running into an issue with wall intersections. My curved glass shower wall is cutting into my straight interior wall, causing it to follow the curve. I need the interior wall to extend slightly farther out, but when I try using the “Edit Wall Layer Intersection” tool, because the walls are so close together, it keeps snapping back and won’t allow me to extend/ adjust the interior wall. Is there an option in the wall specifications that define which wall cuts the other wall? Thanks in advance. Link to comment Share on other sites More sharing options...
