Dimensions ?
Kelly_K
Is it me or a new setting that I can't find, because it seems like dimensioning to walls has gone backwards under X7.  I like to use end to end a lot and then choose the walls I wish to dim.  I am set to primary wall side and nothing else, but I find I am picking up centers and sheet rock not the framing.
Kelly,
Why not use Auto Dimensions?  If there are some you don't want you can just grab the extension line and move it - that dimension will disappear.
But you are correct that the Manual Dimension Tools are picking up more than just the Main Layer.  I don't recall that in X6 - but OTOH, I seldom use Manual Dimensions.
