High shed roof wall window issues
SimpleSpaces
Good morning! I am stuck on what seems to be simple fix. I am drawing a simple 14 x 20 cabin with a shed roof. I can't get the framing to stop running through the windows on the high side. The back wall is 7', hence why the framing is running all the way around, but I don't know how to fix it. Any help would be appreciated! I'm using Home Designer Pro 2021.
Hello @SimpleSpaces,
It looks like that wall isn't set to follow its default top height, which is causing the framing to generate incorrectly.
To fix this:
1. Select the problem wall and open its specification
2. Go to the Structure panel and check the box for Default Wall Top Height
3. Rebuild your wall framing
I hope this helps!
